AC compressor
Our ac compressor is making noise. Hubby says it looks like a pain to replace.
Anyone replace theirs? How difficult is it? L/MM |
well mine just went :
Meineke install 1200$ Pep Boys install 975$ Joes Auto 700$ all of them are using rebuild compressors, yes it pays to shop around |
Like Marm said, check your tensioner first. If you have to replace it, it really isn't as bad a job as it looks. Once you get under the car, you'll be able to see it isn't any more trouble than replacing the starter.
Sorry if I confused ya bro. :seasix: |
I just did the water pump on the old car, and with the pump off the compressor was fairly accessible. Dependent on mileage, consider doing a pump as it needs to come off to replace the compressor. At that point the labor is free. Just noticed this was posted 2 years ago. Probably fixed by now.
I did the A/C compressor in the mid 60K's, changed out the water pump while it was apart. Now, at 130K I had a sticky t-stat, a leaking connector on the surge tank, and a sporatic purge of coolant from the water pump. So I changed out the pump, tank, t-stat and belts. All is happy now.
just picked up vert wow i actually get cold air from passenger vents, i always thought the passenger control did not work
very happy indeed figures its raining insanely here, had to quickly cover up vert due to the roof has a hole |
Glad you got it fixed and all is well Chuck. :seasix: |
I swapeed out the compressor without removing the water pump. IIRC, I pulled the driver's side motor mount bolt and lifted the engine a tad.
