OLD Craftsman riding lawn mower......
20 hp Kohler engine.....oil in carb so bad it leaks out......much less the plastic fuel tank leaks out the side....tank is not so much an issue....
BUT the oil in/out of the carb IS.....it will start/run ok, but the oil issue..... anyone?? |
Paging @RED-85-Z51 to the white courtesy phone.
i have a JD lawn mower that won't run.....thankfully, don't really need it to run.
crank case is hooked to carb for blow by.
if the oil level is right,,,, blowby is thick with oil from crank case. so,,,, |
Also could be blow by from worn out rings. |
A baller would get a new one. /thread |
1 Attachment(s)
I would unplug the hose from the crank block 1/2 of it, reatach. :dance: |
Head gasket? Is it OHV or valve in head? OHV are easy and cheap to replace.
Internet says Kohler 20hp are notorious for oil leaks. Remove top cover and check all bolts are tight. Clean air filter. |
You could always just keep a bunch of extra spark plugs handy, so when you foul out one, just pop in another one and use Varsol to clean the fouled plug.
Ditch the carb and figure out a way to retrofit a Crossfire Injection unit instead. With your engineering background, I'm sure you could find a way. Dizzy on top, where it belongs of course. :angel:
