Holy crap
I just changed a rear shock on my C5 in 40 min. :hurray:
So far I’ve done pretty well working on the car. It is pretty intimidating for an old car guy. So far I have removed and flushed the radiators (way harder than it sounds), replaced an AC compressor (seriously), repaired the drivers seat electronics (mice!) and now a magnetic shock. Time to install a supercharger. |
You did put all the nuts and bolts back in, right?
Just checking 'cause you know, yer old. Not mrvette old, but old. |
How many parts did you have left over?
I truly believe the C5 will always be well regarded; it was a radical change from the C4; better in many ways.
Should we mention there are two of them. :island14:
I forgot another repair. I’ve replied my rear window in about five times. I’m a damn pro at it. It usually lasts about a year. Takes about ten minutes. Apparently a common issue with convertibles.
It's pretty common actually. Mine talked to me all the time. :dance: |
The C5 convertible has a glass window that is glued to the soft top. That glue lasts about 10 years. Then it starts separating. The fix is to use something called Rhino Glue (a type of superglue), clean it really well with solvent (acetone works best or toulene). Then I hit the cloth side with 80 grit sandpaper to roughen up and remove some of the adhesive left. (GM used a similar glue) - then, using a couple tricks to take the pressure off the glass (hard to explain), glue it, tape it and put weight on it overnight. Works great and not too hard to do - takes about 20 min. max. That repair lasts 2-3 years. Not great, but better than spending a couple grand on a new top. |
