Shipping and logistics experts. Any here?
Question:
I am shipping a small amount of chemicals. The Hazard Class is Class 9 HOWEVER...the amount of chemicals is an "excepted" amount. That should mean it is not a hazard. We initially placed this label on the shipment... https://images.labelmaster.com/f0000...m/sl350r_0.jpg But the recipient is asking that we use this label along with the one above... https://cdn.jjkeller.com/wcsstore/CV...0x500/1625.jpg This would seem to be in conflict, no? |
Excepted? Doesn't that mean they can't ship it? :confused5:
@Joebuck might be able to answer this one.
It means the quantity is below the threshold of being hazardous. :seasix: Quote:
I’m guessing you have looked at the 49 CFR 172.101 table already
Column 6 specifies codes which represent the hazard warning labels required for a package filled with a material conforming to the associated hazard class and proper shipping name, unless the package is otherwise excepted from labeling by a provision in subpart E of this part, or part 173 of this subchapter. |
Who knew that shipping a BOD was so complicated?:island14:
How much are you shipping?
The product contains small glass vials with a very small amount of acid in them There are 6 pallets of product. If you collected all of the acid in the shipment and poured it in to a single container, there might be two cups, maybe less. |
6 pallets - 48x40x52 - 225lbs each |
Class 9 items are just anything that does not have a specific class and do not require that label if I remember right as long as you're not shipping bulk or internationally. Carriers are also not required to placard the truck either unless it's bulk.
The recipient may require that label to bring it into their facility, that's what we did at O'stock, I would sticker it and call it a day. Anyways, that what I remember. **** yes it will need to be labeled if it ships out of the country. |
