05-05-2016, 2:44pm | #1 | ||||||
[Paging Red]Small Engine Help (Leaf Blower)
I have had my Echo PB-251 Leaf Blower for about 8 or 9 years and it has always served me well. Until today...
Set it to cold start and turned the switch on and pulled the starter rope and immediately noticed it was extremely difficult to pull. So I put it on the ground and had to use considerable force to pull the rope all the way out. Did it a few times and it started leaking fuel. Also, it sounds like hell with a major rattle as it's attempting to turn over. I'm thinking it's toast? |
05-05-2016, 2:59pm | #2 | |||||||
VB Dad of the Year
05-05-2016, 3:03pm | #3 | ||||||
Gameroom Barn Bucks: $111433
I have a pressure washer that isn't wanting to start (Honda engine).
Need to try to clean the carb a bit, but am wondering if it is not getting spark. Replacing the switch/wiring would prove to be a hard part to find. |
05-05-2016, 3:05pm | #4 | |||||||
Damn good tool though, I used the piss out of it. |
05-05-2016, 4:24pm | #5 | ||||||
Barn Stall Owner #13
Gameroom Barn Bucks: $425244
The leaking fuel may be bad fuel lines caused by the ethanol. Easy cheap fix if you want to take an hour or so and $5 in parts. As for the hard pull, I'm not sure
05-05-2016, 4:30pm | #6 | |||||||
VB Dad of the Year
My backpack blower is Echo and I've had it for about 8 years. The only thing broken is the priming bulb, but I can still get it primed and it starts. My weed whacker/edger is Sthil....supposed to be the best in the business...the edger piece went tits up after 3 uses. Was fixed under warranty, but I spent nearly $500 on the main unit plus one extra piece. Echo is a great buy. Just replace when the time is right. |
05-05-2016, 4:35pm | #7 | ||||||
Gameroom Barn Bucks: $4614507
If it was really hard to pull you should have pulled the plug and made sure the cylinder wasn't full of gas or oil from being stored wrong. If it was and you pulled it anyway you may have bent the rod from the lock up.....especially if it's making rattling noises when it started.....
The Following User Says Thank You to Kerrmudgeon For This Useful Post: |
05-05-2016, 4:45pm | #8 | |||||||
Dorkapottamus
Barn Stall Owner #52
Gameroom Barn Bucks: $9339471
05-05-2016, 6:04pm | #9 | |||||||
05-05-2016, 6:04pm | #10 | |||||||
05-24-2016, 10:22am | #11 | |||||||
Gameroom Barn Bucks: $505
05-24-2016, 10:54am | #12 | |||||||
Gameroom Barn Bucks: $1037769
05-24-2016, 10:56am | #13 | ||||||
05-24-2016, 11:18am | #14 | ||||||
1/4 acre burb here, HATE those small engines, bad enuff I have to listen to my electric tools, and gas mower..... trade off all the gas/oil/storage/ethanol crap for a 50000000' electric cord, need get one on a reel....I wind it up about ten feet at a time via a bolt on the wall......
as for the mower, mine is a early Briggs fan belt drive self propelled rotary, 22" and I put wheel barrow wheels in the rear, for ease of handling, and rigged the RPM to about twice normal speeds, so I run after it......get it the hell over with and too boot more HP at the blade, so no bog in thick grass.... I put a fuel cut off valve and my own kill switch on it...the fuel in the tank does not flood out the carb in storage that way.....disabled all the crap .gov shit.... opened up the side of the mower for a discharge, no bags..... to fix the carb, if necessary, drop the bowl, leave the float crap in place, shot of brake cleaner through the fuel line, blow it out with air jet, and reassemble, ready for another 3 years or better..... I removed the recoil starter and have 15' of cord on my 1/2 inch electric drill, and a welded on socket on a cut off 3/8 drive extension, in the drill, I start the engine via the magneto bolt on top.....the one on the crank..... rigged all this up over the last ~16 years, so to make mowing easy....and reliable..... GOD, I"M LAZY!!!! |
05-24-2016, 2:59pm | #15 | |||||||
Barn Stall Owner #1269
Gameroom Barn Bucks: $232471
05-24-2016, 3:43pm | #16 | ||||||
I bought a new Echo blower about a week or so ago.
05-24-2016, 4:00pm | #17 | ||||||
Gameroom Barn Bucks: $11051621
I have gotten an Echo chainsaw and weedwacker on Reds advice, both awesome products. Sounds like the blower may be past repair but replacement parts can be bought. Compare the price of replacing it with a new one and you may go fro the repair.
