05-29-2016, 10:57am | #1 | ||||||
Dorkapottamus
Barn Stall Owner #52
Gameroom Barn Bucks: $9339471
Anyone know where I can find these wheels?
I think they're Western Bullet style. 14" x 6", Chevrolet bolt pattern.
05-29-2016, 12:58pm | #2 | ||||||
Barn Stall Owner #457
05-29-2016, 1:43pm | #3 | |||||||
Dorkapottamus
05-29-2016, 1:53pm | #4 | ||||||
Gameroom Barn Bucks: $4614507
As long as the bolt pattern is the same and front/rear clearances are good, there's no problem. Just need new tires. I've always swapped around sizes. Going down in size would be a problem to clear brakes and stuff. those are even made for the cho cho edition of the elkie.
05-29-2016, 1:55pm | #5 | |||||||
Dorkapottamus
05-29-2016, 2:31pm | #6 | ||||||
Dorkapottamus
05-29-2016, 2:40pm | #7 | |||||||
Your speedo/odometer will read a little off, but you can get the right plastic gear for your trans pretty easy, or go to a lower profile tire to get the approximate original height.
05-29-2016, 8:23pm | #8 | ||||||
Gameroom Barn Bucks: $3122345
05-29-2016, 8:28pm | #9 | ||||||
Goldilocks
Gameroom Barn Bucks: $1009320
05-29-2016, 8:40pm | #10 | ||||||
Barn Stall Owner #2112
Gameroom Barn Bucks: $3043611
05-29-2016, 9:15pm | #11 | ||||||
05-31-2016, 4:22pm | #12 | ||||||
05-31-2016, 4:48pm | #13 | ||||||
have you tried calling Hennessey?
06-01-2016, 8:13am | #14 | ||||||
I've called Hennessey lots of things. Be more specific.
https://tiresize.com/calculator/ Speedometer problem solved. |
06-01-2016, 5:03pm | #15 | ||||||
Barn Stall Owner #92
Gameroom Barn Bucks: $7534993
You also need to know what lug nuts they use. A lot of later G-Body wheels use the metric tapered lug. When I swapped 87 Monte SS wheels on my 81 Malibu, I had to change the studs and lug nuts as the standard lugs had a different seat taper.
